8 years agoalt_timestamp_start() return -1
hi i build nios system with timer and set the bsp (timestamp,timer) compile is ok but when i run the alt_timestamp_start() get -1 and alt_timestamp() also return -1 !! the nticks() w...
Balle2
7 years ago""I can't see it clearly, but I think you set both your sys_clk_timer and timestamp_timer to be timer0? Can you disable the sys_clk_timer instead? Also remember to press the generate button.""
