1 Reply
They should be present, the new interrupt API is the default though. If you take a look at the system.h file you should see a macro called something like "ENHANCED_INTERRUPT_API" set to 1 which causes the new API to be used. For more details I would take a look at this document: http://www.altera.com/literature/hb/nios2/n2sw_nii52006.pdf
