alt-file-convert error
- 4 years ago
This flow is for MAX 10 as documented, I have found a KDB related to this issue:
https://www.intel.com/content/www/us/en/support/programmable/articles/000086355.html
I believe you have done the above workaround, but just to confirm that you have executed the command from a Nios II Command Shell?
May I know where is your project file located when executing the command?
Is it local or network drive? Can you try placing your project folder on a local drive? If already, execute Nios II Command Shell as Admin (run as Admin...) and re-try.
I was able to generate on Linux 18.1, now I am trying on Windows next.
I have not face the same error, can you please re-try below:
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/application-42772.html
And make sure your path of the project along with the sopc is in the right directory.
- Naji_Naufel_Arrow4 years ago
My files are in the folders that Quartus chooses for them.
What do you mean by "the right directory"
Thank you.
This flow does not work for MAX10.
Thank you,
