alt_avalon_i2c_master_tx will always fail with -1 error code
In basic I have this:
module top (
input clk,
output [7:0] led,
inout tri1 i2c_scl,
inout tri1 i2c_sda
wire i2c_scl_in;
wire i2c_sda_in;
wire i2c_scl_oe;
wire i2c_sda_oe;
assign i2c_scl_in = i2c_scl;
assign i2c_sda_in = i2c_sda;
assign i2c_scl = i2c_scl_oe ? 1'b0 : 1'bz;
assign i2c_sda = i2c_sda_oe ? 1'b0 : 1'bz;
pro13_i2c_port u0 (
.clk_clk (clk), // clk.clk
.led_external_connection_export (led),
.i2c_0_i2c_serial_scl_in (i2c_scl_in),
.i2c_0_i2c_serial_sda_in (i2c_sda_in),
.i2c_0_i2c_serial_scl_oe (i2c_scl_oe),
.i2c_0_i2c_serial_sda_oe (i2c_sda_oe)
endmodule
And here my Nios II code:
#include "sys/alt_stdio.h"
#include <stdio.h>
#include "system.h"
#include "altera_avalon_pio_regs.h"
#include "altera_avalon_uart_regs.h"
#include "altera_avalon_i2c.h"
#include "altera_avalon_i2c_regs.h"
const alt_u8 SLAVE_ADDRESS = 0x40;
ALT_AVALON_I2C_DEV_t *i2c_dev; //pointer to instance structure
int I2C_INIT()
ALT_AVALON_I2C_STATUS_CODE status;
//get a pointer to the avalon i2c instance
i2c_dev = alt_avalon_i2c_open("/dev/i2c_0");
if (i2c_dev == NULL)
IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE, 0x01);
return 1;
alt_avalon_i2c_disable(i2c_dev);
ALT_AVALON_I2C_MASTER_CONFIG_t* cfg;
cfg->addr_mode = ALT_AVALON_I2C_ADDR_MODE_7_BIT;
cfg->speed_mode = ALT_AVALON_I2C_SPEED_STANDARD;
alt_avalon_i2c_master_config_set(i2c_dev, cfg);
//set the address of the device using
alt_avalon_i2c_master_target_set(i2c_dev, SLAVE_ADDRESS);
IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE, 0x02);
return 1;
status = alt_avalon_i2c_enable(i2c_dev);
if (status != ALT_AVALON_I2C_SUCCESS)
IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE, 0x04);
return 1; //FAIL
return 0;
int I2C_SENT()
//write data to an I2C device
alt_u8 txbuffer[2];
txbuffer[0] = 0x00;
txbuffer[1] = 0x00;
status = alt_avalon_i2c_master_tx(i2c_dev, txbuffer, 2, ALT_AVALON_I2C_NO_INTERRUPTS);
IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE, ~abs(status&0xff));
return 1; //FAIL
return 0;
int main()
IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE, 0x00);
I2C_INIT();
/* Event loop never exits. */
while(1){
delay(2);
I2C_SENT();
delay(2);
return 0;
Any idea why alt_avalon_i2c_master_tx will always fail with -1 error code?
- PHeri1
Update from my side:
Error code is NOT -1 but -7 (ALT_AVALON_I2C_BUSY)
- druva1
I recommend to check this example of Master - slave communication: https://www.macnica.co.jp/business/semiconductor/articles/intel/129485/
even though is in Japanese (use google translate to read the pdf with the instructions) you can get the example files, they worked for me.
Cheers
- PHeri1
unfortunately, this example exits with error code -2 (ALT_AVALON_I2C_TIMEOUT)
- druva1
Which board do you have? Because I had to create a new project and then I replicated the qsys to my board, put the weak resistors, the 3.3 Voltage, and then it worked, re type the code due to the funny characters.
If you have an arduino board you can also used it as a Slave, is almost guarantee it will easily work with it, and it will help you out to understand things.
- PHeri1
I have a DE10-Lite board. I had to rename the pins so that they match with my board and I had to resize the memory size in the Platform Designer.
Maybe I am not using the appropriate pins, but I saw a post here that you could use every pin of the 10M50DAF484C7G for I2C purposes.
What I noticed is, when I select the MAX 10 DE10-Lite board in Quartus it selects a 10M50DAF484C6GES devices, but the board has an 10M50DAF484C7G. Maybe no big deal.
Now, when creating a new project I select a 10M50DAF484C7G manually.
Normally I use these pins: PIN_AB5, PIN_AB6, but I also tried, to be compatible with an Arduino, ARDUINO_IO[14] (PIN_AB21) and ARDUINO_IO[15] (PIN_AA20) without any luck.
I do get a lot of warnings when compiling. One of them is that a bidirectional pin cannot be tri-stated.
- PHeri1
I wil create the whole project from scratch today like you did. See if it helps.
