12 years agoAddress missmatch in triple_speed_ethernet tutorial when setting Block Diagram as Top
Hallo,
i have a Verilog file from the tutorial: "Using Triple Speed Ethernet on DE2-115 Boards" ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/de2-115/using_triple_speed_ethernet.pdf I am trying to build the same verilog file in a Block diagramm and set it as a Top Entity. In the verilog file, i have 3 Instances. I took the Instances and added them seperatly to the Block Diagramm. My project ist working fine with the Verilog file as Top entity. When i set the Block diagramm as Top Entity, i get some problems in Eclipse: Verifying 00080000 ( 0%) Verify failed between address 0x80000 and 0x86183 Leaving target processor paused I compared the designs in RTL viewer. Both designs in RTL Viewer look alike ! Anyone have a clue whats going wrong ? I need to seperate the 3 Inst. in the Block Diagramm and i cant use the option "create Symvol Files for current file" !!No RepliesBe the first to reply
