21 years agoAddress alignment
1. There are IORD,IOWR routines. It is right to IORD_32DIRECT("*000 *004 *008 *00C")! Then is it right to IORD_32DIRECT("*001 *005 *009 *00C...") or IORD_8DIRECT("*001 *002 *003 *004...") when a...
21 years agomountain8848,
1) Registers are internally 32-Bits wide, but only the lower 8 bits are used in your case. With A2-A0 you have 8 locations that spans an area of 8 x 4Bytes = 32Bytes in the memory map (0x0 - 0x1F). Consecutive writes to these locations can be done as*(alt_u8 *)(BASE + 0) = 1;
*(alt_u8 *)(BASE + 4) = 2;
*(alt_u8 *)(BASE + 8) = 3;
or
*(alt_u8 *)(BASE + 3) = 1;
*(alt_u8 *)(BASE + 7) = 2;
*(alt_u8 *)(BASE + 11) = 3;
or
*(alt_u32 *)(BASE + 0) = 1;
*(alt_u32 *)(BASE + 4) = 2;
*(alt_u32 *)(BASE + 8) = 3; which will have the same results. The address A[4..2] of an Avalon-Master are mapped to A[2..0] of the register slave, as you supposed. 2) The difference between SRAM and SDRAM connected to TRi-State-Avalon is, that there is a special SDRAM-controller, managing different row- and column- addresses. During a SDRAM-access, these address lines are multiplexed with absolute Avalon addresses. So it depends on the actual access if row-addresses, column-addresses or absolute addresses are present on these lines. In this special case A0 means A0! (I also had to correct this in my design). Mike
