16 years agoAdding ssram to NIOS
Hello! I would like to add some RAM to the NIOS processor. I am using the NEEK kit. So in SOPC builder, I have added ssram. As there was an error message, I also added an AVALLON MM tristat...
16 years agoHello Andreas!
Thanks for your reply! Here is a report (http://passworld.co.jp/forummsp430/viewforum.php?f=18) of what I did. The first tutorial works fine, the second one will certainly work as soon as I can solve the SSRAM clock problem. --- Quote Start --- Hi, I think you just have to put a clock signal with apropriate frequency (same frequency as defined in sopc) on this pin. --- Quote End --- Yes, I know that, but my problem is simply: how do I do that? I know from many sources (schematics, other sample programs, etc) that the clock has to be wired to PIN_A9 (as far as I remember correctly) and that the SSRAM clock has to be wired to PIN_A2. When I added the NIOS processor in SOPC builder, the clock signal was automagically generated and could be found in the "*_inst.v" file. Now in pin planner, I have assigned the clock pin to A2 and it works (the first tutorial works). Now I canot assign the clock to A9. Not in pin planner anyway, because in this case SSRAM will have a clock, but NIOS will have no clock anymore. I suspect I have to create a new node (for instance ssram_clk), and use one of the tools to make a bridge from sysclk (input) to ssram_clk (output). So in short: how would you do that? --- Quote Start --- Follow the advices in this thread: Damn, I can´t post links so use google and take the first hit. Google for: "Problems with pin assignments with Cyclone III starter board" --- Quote End --- Yes, in the meantime, I found the solution, and there is an extensive explanation in my "Tutorial 2-1: NIOS + SRAM" in the link above. Thanks! Pascal
