16 years agoAdding ssram to NIOS
Hello!
I would like to add some RAM to the NIOS processor. I am using the NEEK kit. So in SOPC builder, I have added ssram. As there was an error message, I also added an AVALLON MM tristate bridge. Apparently SOPC is happy with it, there are no errors. Just in case, I also looked to the SOPC design of Cyclone III NIOS II video sample code. The ssram is connected the same way, so I suppose this part is right. sram clock problem Now when I generate the system, I obtain the following instantiation sample:niossram niossram_inst
.address_to_the_ssram (address_to_the_ssram),
.adsc_n_to_the_ssram (adsc_n_to_the_ssram),
.bw_n_to_the_ssram (bw_n_to_the_ssram),
.bwe_n_to_the_ssram (bwe_n_to_the_ssram),
.chipenable1_n_to_the_ssram (chipenable1_n_to_the_ssram),
.data_to_and_from_the_ssram (data_to_and_from_the_ssram),
.out_port_from_the_LEDs (out_port_from_the_LEDs),
.outputenable_n_to_the_ssram (outputenable_n_to_the_ssram),
.reset_n (reset_n),
.sysclk (sysclk)
However, in this instantiation, there is no clock dedicated to SRAM. So here is the problem: how do I get an output from NIOS to SRAM? sram address bus problem I have been looking at samples, namely the NEEK_VIP_DEMO_LCD_SVGA, just to know which pins go where. There I noticed that the addresses don't begin at 0, but at 1. I was told that it's because the NIOS input is 8 bit and therefore the 2 last bits are unused. Shouldn't it begin at 2 in this case? Now isn't there a problem if I conect Now I have looked at the pinout of the cyclone_III_3c25_niosII_video and the scram clock is at pin labeled "PIN_A2". So if I don't assign some clock to this PIN_A2 in my pin assignment, I guess the scram will get no clock. Can anyone tell me how to solve this? sram data bus problem Now I have tried to compile as is. But there is another problem: I get this message: Error: Can't place multiple pins assigned to pin location PIN_D1 (IOPAD_X0_Y27_N7) Error: Can't place multiple pins assigned to pin location PIN_H3 (IOPAD_X0_Y22_N7) Pins D1 and H3 are the data bus D1 and D0. But I verified in NEEK_VIP_DEMO_LCD_SVGA (this one compiles) that the data bus is exactly at the same pins. Could anybody give me hints? Thanks. Pascal2 Replies
I found this thread on the search of how to put the ssram into operation. My ssram seems to work now, so I write how I think it is: --- Quote Start --- Shouldn't it begin at 2 in this case? --- Quote End --- You are right, for the ssram it should begin at 2, because it has a 32 bit word size. But in the example there is also the flash memory which has a word size of 16 bit, and both memorys share the same addressbus. So I guess for the sake of the flash it includes a[1]. My sopc don´t use the flash so I left tristate-bridge at defaults. (no bus sharing, because senseless without more than one slave) My sopc has a 20 bit addressbus for the ssram. Makes sense because 2^20 = 1 M, so one address for each byte of the ssram-memory as mentioned in "Avalon Interface Specifications". I took bit 19 to 2 of this addressbus to the flash_sram_a[19..2] pins according to CIII FPGA Starter Board Reference Manual. At least a hello world programm runs in that way (I haven´t tested more than that till now). I hope the tristate bridge manages the writebyteenable bus bw_n to use the complete memory, but still have to test that. --- Quote Start --- Now I have looked at the pinout of the cyclone_III_3c25_niosII_video and the scram clock is at pin labeled "PIN_A2". So if I don't assign some clock to this PIN_A2 in my pin assignment, I guess the scram will get no clock. Can anyone tell me how to solve this? --- Quote End --- I think you just have to put a clock signal with apropriate frequency (same frequency as defined in sopc) on this pin. --- Quote Start --- sram data bus problem Now I have tried to compile as is. But there is another problem: I get this message: Error: Can't place multiple pins assigned to pin location PIN_D1 (IOPAD_X0_Y27_N7) Error: Can't place multiple pins assigned to pin location PIN_H3 (IOPAD_X0_Y22_N7) Pins D1 and H3 are the data bus D1 and D0. But I verified in NEEK_VIP_DEMO_LCD_SVGA (this one compiles) that the data bus is exactly at the same pins. Could anybody give me hints? --- Quote End --- Follow the advices in this thread: Damn, I can´t post links so use google and take the first hit. Google for: "problems with pin assignments with cyclone iii starter board" Regards Andreas - Altera_Forum
Hello Andreas!
Thanks for your reply! Here is a report (http://passworld.co.jp/forummsp430/viewforum.php?f=18) of what I did. The first tutorial works fine, the second one will certainly work as soon as I can solve the SSRAM clock problem. --- Quote Start --- Hi, I think you just have to put a clock signal with apropriate frequency (same frequency as defined in sopc) on this pin. --- Quote End --- Yes, I know that, but my problem is simply: how do I do that? I know from many sources (schematics, other sample programs, etc) that the clock has to be wired to PIN_A9 (as far as I remember correctly) and that the SSRAM clock has to be wired to PIN_A2. When I added the NIOS processor in SOPC builder, the clock signal was automagically generated and could be found in the "*_inst.v" file. Now in pin planner, I have assigned the clock pin to A2 and it works (the first tutorial works). Now I canot assign the clock to A9. Not in pin planner anyway, because in this case SSRAM will have a clock, but NIOS will have no clock anymore. I suspect I have to create a new node (for instance ssram_clk), and use one of the tools to make a bridge from sysclk (input) to ssram_clk (output). So in short: how would you do that? --- Quote Start --- Follow the advices in this thread: Damn, I can´t post links so use google and take the first hit. Google for: "Problems with pin assignments with Cyclone III starter board" --- Quote End --- Yes, in the meantime, I found the solution, and there is an extensive explanation in my "Tutorial 2-1: NIOS + SRAM" in the link above. Thanks! Pascal
