10 years agoAdding lighttpd-fastcgi to Poky version
Thanks in advance.
I may be going about this all wrong, so please advise. I've got a Macnica Cyclone V board that has a Poky 8.0 (Yocto Project 1.3 Reference Distro) 1.3 socfpga. I'm using the lighttpd that came with this distro# ] lighttpd -v lighttpd/1.4.31 - a light and fast webserver Build-Date: Jun 24 2014 09:52:47 I want to add fastcgi support -- when I've used the Angstrom version it's easy you just need to "opkg install lighttpd-module-fastcgi" So, I figured I'd add opkg from the Angstrom release and do it that way. Change the lighttpd.conf file to enable fastcgi. But when I try to start lighttpd I get. root@socfpga:~# /etc/init.d/lighttpd start Starting Lighttpd Web Server: 2014-06-24 05:12:11: (plugin.c.421) plugin-version doesn't match lighttpd-version for fastcgi 2014-06-24 05:12:11: (server.c.926) Initialization of plugins failed. Going down. lighttpd. root@socfpga:~# SO - I figure EITHER 1. The /etc/opkg/ .conf files are not going to the correct spot to get what I need. Since these go to Angstrom sites. 2. I can't use opkg. Can anyone EDUCATE ME? ThanksNo RepliesBe the first to reply
