10 years agoAdd other file (vhdl) in project with .qip.
Hi, good morning, I'm trying add another file (vhdl) in quartus project, with .qip. I need that my application has an little module in vhdl, but I'm not getting run. Or may set an file as t...
10 years agoNot sure what the question is - you can only assign pins to the top level module. If you need to add a sub module that connects to pins on the device, you need to route the signals up to the top level.
