12 years agoACP port under Linux
Hi, Is there any trick to using the ACP port from FPGA under Linux (3.9)? I'm setting the f2h AR & AW CACHE/PROT/USER by hand, post-qsys, but don't see any indication that the SCU cares at all...
10 years agoHello again,
I am trying to setup the ACP port, so I have some questions: 1. Do I need to use the FPGA to HPS port instead the FPGA to SDRAM ports? 2. Do I need to cast the buffer I allocated in the driver to a 'unsigned long long' to read/write data? is it required? 3. Is it required to set the f2h_AR[AW]CACHE attributes as you said in the second post? 4. After sending the command to perform the DMA task using the ACP port (phy_addr | 0x80000000) I got a "Kernel panic - not syncing", do you have a repository where I can take a look at the code of your driver when using the ACP? And the FPGA qsys system. Also this is the Linux I am using: Linux cyclone5 3.10.31-ltsi-altera# 1 SMP Thu Feb 11 22:06:58 UTC 2016 armv7l GNU/Linux and the DE1-SoC board. Thanks.
