12 years agoACP port under Linux
Hi, Is there any trick to using the ACP port from FPGA under Linux (3.9)? I'm setting the f2h AR & AW CACHE/PROT/USER by hand, post-qsys, but don't see any indication that the SCU cares at all...
10 years agoThanks for you quick reply Sir.
Now, why did you say the FPGA-SDRAM port is faster than ACP port, I have read that by using the ACP port you can get data that is cached, so you don't have to read/write data to the DDR SDRAM in some cases. I am using the DE1-SoC board. If by using the FPGA-SDRAM ports I will get better performance, can you explain me how to use the dma_sync_single_for_device/cpu functions. I am working of a project where I have a user application which will send some information to the FPGA module I have developed (some like a DMA module, but it doesn't move data in the way *dest++ = *src++), so how can I allocate physical memory that I can share between the FPGA and CPU? and what it the use of the dma_sync... functions?
