12 years agoACP port under Linux
Hi, Is there any trick to using the ACP port from FPGA under Linux (3.9)? I'm setting the f2h AR & AW CACHE/PROT/USER by hand, post-qsys, but don't see any indication that the SCU cares at all...
10 years ago --- Quote Start --- Hi Sir, I am trying to interface a linux program to a FPGA master using the ACP port, what address do I need to use to ensure read and writes go through the ACP port? Actually I am not familiar with using the ACP port at all, if you can give me some guide, I will appreciate it. I configured the AXI port cache settings as you said. Any example or reference where I can find information related to it. Thanks. --- Quote End --- Hi norxander, For access to ACP port, my driver code looks like (literally): dma->csr[2] = c->dma_currimage.write_buf_phys_addr | 0x80000000; The bit-wise OR was the only trick. However, I found the ACP speed slow and I gave up on ACP port and used the much faster FPGA-SDRAM ports. I've heard rumors that ACP port has a design flaw that will be fixed. My notes apply to Cyclone 5 SoC 5CSXFC6D6F31C8ES and you'll find best performance there by using the FPGA-SDRAM ports and using driver calls dma_sync_single_for_device/cpu on buffers shared between FPGA and CPU. Best wishes
