12 years agoACP port under Linux
Hi, Is there any trick to using the ACP port from FPGA under Linux (3.9)? I'm setting the f2h AR & AW CACHE/PROT/USER by hand, post-qsys, but don't see any indication that the SCU cares at all...
11 years agoThe answer turned out to be surprisingly simple. Make sure the physical address passed by the driver to the FPGA accelerator is "| 0x80000000". This puts the address in the ACP range. Otherwise, the address bypasses the SCU.
This also allows one to test performance with and without the ACP by simply changing the address at runtime. Thanks to LegUp for the solution: http://janders.eecg.toronto.edu/pdfs/euc14.pdf Note: cache attributes set by hand in the top level HDL after Qsys compile are: .f2h_ARCACHE (4'hf) .f2h_ARPROT (3'h0) .f2h_ARUSER (5'h1f) .f2h_AWCACHE (4'hf) .f2h_AWPROT (3'h0) .f2h_AWUSER (5'h1f) ACDS is 14.0.
