15 years agoAchieving higher performance?
Hello i want to make my design as fast as possible to run uCLinux, my software is running at 40ms and should run at 8ms. I am using a linux with MMU, 50mhz clock, 32k Data and instruction Cache...
15 years agoMy clock configuration at the QSys is correct. The SDRAM clock is -67 degrees from my sys_clock and it is running at a supported speed (took a look at the datasheet)
I made this SDC file:create_clock -period 20.000 -name clkin_50
derive_pll_clocks
derive_clock_uncertainty
