14 years agoAcess data wordwise from Nios II
I have a 16 bit wide Flash memory and a 32 bit wide RAM attached to the Nios II. In the evaluation kit (Altera Embedded Systems Development Kit, Cyclone III Edition) address bit 0 is omitted for the Flash memory and address bits 0 and 1 are omitted for the RAM. How can I make sure the data is only addressed wordwise? Or will the Nios II by default address the memory wordwise? Regards Martin1 Reply
If anybody has the same question here is the response I got from the Altera support:
For masters, the address signal represents a byte address. The value of the address must be aligned to the data width. To write to specific bytes within a data word, the master must use the byteenable signal. For slaves, the inter-connect translates the byte address into a word address in the slave’s address space so that each slave access is for a word of data from the perspective of the slave. For example, address= 0 selects the first word of the slave and address 1 selects the second word of the slave. Please refer to the following user guide page 30 "Avalon MM salve addressing". http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
