14 years agoAcess data wordwise from Nios II
Hello, I have a 16 bit wide Flash memory and a 32 bit wide RAM attached to the Nios II. In the evaluation kit (Altera Embedded Systems Development Kit, Cyclone III Edition) address bit 0 is omi...
14 years agoIf anybody has the same question here is the response I got from the Altera support:
For masters, the address signal represents a byte address. The value of the address must be aligned to the data width. To write to specific bytes within a data word, the master must use the byteenable signal. For slaves, the inter-connect translates the byte address into a word address in the slave’s address space so that each slave access is for a word of data from the perspective of the slave. For example, address= 0 selects the first word of the slave and address 1 selects the second word of the slave. Please refer to the following user guide page 30 "Avalon MM salve addressing". http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
