12 years agoAccessing inputs and outputs of a custom component
Hello every body;
I have created my custom compnent caled "cipher", it takes 2x128 bits input and produce one 128bit ouput, the component definition in system.h is: #define ALT_MODULE_CLASS_Cipher_0 Cipher #define CIPHER_0_BASE 0x201020 #define CIPHER_0_IRQ -1 #define CIPHER_0_IRQ_INTERRUPT_CONTROLLER_ID -1 #define CIPHER_0_NAME "/dev/Cipher_0" #define CIPHER_0_SPAN 32 #define CIPHER_0_TYPE "Cipher" My Quistions are: 1-what is the address of the inputs and outputs. 2-how can i access them if i want to pass and read the inputs and the outputs as 4x4 array. Thanks.5 Replies
--- Quote Start --- 1-what is the address of the inputs and outputs. --- Quote End --- CIPHER_0_BASE + offset where 'offset' is whatever register addresses you have defined within your custom component (i.e. how you decode the 'address' on the Avalon-MM Slave port) --- Quote Start --- 2-how can i access them if i want to pass and read the inputs and the outputs as 4x4 array. --- Quote End --- You can use IORD/IOWR macros to access the registers you have created one at a time. - Altera_Forum
Thanks Ted for your reply>
but I have an address span of 32 byte or (16 byte for each input), here what is the base address of the output ? - Altera_Forum
You need to take care of address in your custom component.Address will be as shown in below code.
//RTL Code for write logic case({av_write,av_address[4:0]}) 6'b1_00000 cipher_in1[31:0] <= av_wrdata; 6'b1_00100 cipher_in1[63:32] <= av_wrdata; 6'b1_01000 cipher_in1[95:64] <= av_wrdata; 6'b1_01100 cipher_in1[127:96] <= av_wrdata; 6'b1_10000 cipher_in2[31:0] <= av_wrdata; 6'b1_10100 cipher_in2[63:32] <= av_wrdata; 6'b1_11000 cipher_in2[95:64] <= av_wrdata; 6'b1_11100 cipher_in2[127:96] <= av_wrdata; endcase //RTL code for read logic case(av_address) 0 : av_rddata <= cipher_out[31:0]; 4 : av_rddata <= cipher_out[63:32]; 8 : av_rddata <= cipher_out[95:64]; 12 : av_rddata <= cipher_out[127:96]; endcase //NIOS Code //Cipher Input 1 IOWR(CIPHER_0_BASE,0x00,0x03020100); IOWR(CIPHER_0_BASE,0x04,0x07060504); IOWR(CIPHER_0_BASE,0x08,0x0b0a0908); IOWR(CIPHER_0_BASE,0x0c,0x0f0e0d0c); //Cipher Input 2 IOWR(CIPHER_0_BASE,0x10,0x03020100); IOWR(CIPHER_0_BASE,0x14,0x07060504); IOWR(CIPHER_0_BASE,0x18,0x0b0a0908); IOWR(CIPHER_0_BASE,0x1c,0x0f0e0d0c); - Altera_Forum
--- Quote Start --- Thanks Ted for your reply> but I have an address span of 32 byte or (16 byte for each input), here what is the base address of the output ? --- Quote End --- You would need to review the custom component (Verilog/VHDL) you created and understand what address is supplied to it in order to read the 'output'. It sounds like maybe you havent declared a wide enough address space to fit (3) 128-bit elements? - Altera_Forum
Thanks ted for your attentions;
I tried what you have illustrated and worked well with me, now, my custom logic takes 26 clk cycles to produce the output, how can i access the output just it finish processing the inputs.
