12 years agoAccessing inputs and outputs of a custom component
Hello every body; I have created my custom compnent caled "cipher", it takes 2x128 bits input and produce one 128bit ouput, the component definition in system.h is: #define ALT_MODULE_CLAS...
12 years agoYou need to take care of address in your custom component.Address will be as shown in below code.
//RTL Code for write logic case({av_write,av_address[4:0]}) 6'b1_00000 cipher_in1[31:0] <= av_wrdata; 6'b1_00100 cipher_in1[63:32] <= av_wrdata; 6'b1_01000 cipher_in1[95:64] <= av_wrdata; 6'b1_01100 cipher_in1[127:96] <= av_wrdata; 6'b1_10000 cipher_in2[31:0] <= av_wrdata; 6'b1_10100 cipher_in2[63:32] <= av_wrdata; 6'b1_11000 cipher_in2[95:64] <= av_wrdata; 6'b1_11100 cipher_in2[127:96] <= av_wrdata; endcase //RTL code for read logic case(av_address) 0 : av_rddata <= cipher_out[31:0]; 4 : av_rddata <= cipher_out[63:32]; 8 : av_rddata <= cipher_out[95:64]; 12 : av_rddata <= cipher_out[127:96]; endcase //NIOS Code //Cipher Input 1 IOWR(CIPHER_0_BASE,0x00,0x03020100); IOWR(CIPHER_0_BASE,0x04,0x07060504); IOWR(CIPHER_0_BASE,0x08,0x0b0a0908); IOWR(CIPHER_0_BASE,0x0c,0x0f0e0d0c); //Cipher Input 2 IOWR(CIPHER_0_BASE,0x10,0x03020100); IOWR(CIPHER_0_BASE,0x14,0x07060504); IOWR(CIPHER_0_BASE,0x18,0x0b0a0908); IOWR(CIPHER_0_BASE,0x1c,0x0f0e0d0c);
