15 years agoAccessing Custom Components in Nios
Hey guys, I've made a custom component to interface between Nios and some verilog. I've attached a screenshot of the signals. If a FIFO megafunction from 9.1 (because FIFO makes 10.1 and...
15 years agoNios II only can access memory mapped slave *interfaces* not the signals that make up the interface. To access this FIFO you probably should include "io.h" and use one of the IORD macros defined in it. Searching for "io.h" or "IORD" in the Nios II software handbook for more details. These macros perform cache bypassing read accesses to whatever address you pass into it.
