12 years agoaccesing a custom component
Hello every body; I have created my custom component, it have an avalon slave interface, it have 2 slave registers, how can i access these registers if i have the base address, i mean that what is...
12 years ago --- Quote Start --- I have created my custom component, it have an avalon slave interface, it have 2 slave registers, how can i access these registers if i have the base address, i mean that what is the order of these internal registers, --- Quote End --- Every register you implement in the custom component is supposed to have an address (or offset) inside the MM slave address range. This depends only on your hw design. --- Quote Start --- another question is if this component takes 20 clk cycle to finish, how can i take its output when it just finish. --- Quote End --- Three options: - wait at least 20 clk with a sw cycle - implement a status register with a completion flag bit: then poll the bit until the it signals your data is ready; this is especially useful when the process duration is not constant - route the completion signal to an irq
