20 years agoabout sdram a/d bus shared
hi all:
In tne altera reference design, the SDRAM not share address/data bus with flash, sram, lan chip. But in my design I shared sdaram address/data bus with flash to reduce IO pins. Now I meet a problem. I can run the single program fine without OS.But when I run uClinux 2.6 os on own board the system will boot fail.The fail information is CRC erro. However I run the same uClinux 2.6 os on altera cyclone 1c20 dev board, it is work fine.The difference is my design shared the SDRAM a/d bus with flash.I think maybe the reason is disturb. Who can give me some advice to solve the question? Thank a lot!No RepliesBe the first to reply
