10 years agoabout reset vector address
hi everybody I want to know If I debug use the JTAG , does the reset vector address have any influence ? I set the reset vector address on ext flash. where do the code start to run ᦃ...
10 years ago --- Quote Start --- Which external flash are you using? --- Quote End --- nor flash.where do the code run from when debug using the jtag?
