21 years agoAbout host file system
I used the altera host file system to open a file .mp3,, is this a legal operation or not? if it is legal then why [[FILE *hostfile =fopen ("/mnt/host/song.mp3","rb");]] return NULL!! can any...
15 years ago --- Quote Start --- You've pasted code that has had its quotes changed. --- Quote End --- I've also used another example which had some quotes changed: int main() // Load and read back filter coefficients two times { FILE * hostfile = fopen("/mnt/host/hello_hostfs.txt", "w"); char buffer[1024]; while (fgets(buffer, sizeof(buffer), hostfile) != null) { fprintf(stdout, "%s", buffer); } fclose(hostfile); printf("That's all folks\n"); and I get error messages such as: Compiling topavalon.c... ../topavalon.c: In function `main': ../topavalon.c:73: warning: implicit declaration of function `floor' Linking epuisant.elf... obj/topavalon.o(.text+0x24): In function `main': ../topavalon.c:33: undefined reference to `fopen' obj/topavalon.o(.text+0x38):../topavalon.c:35: undefined reference to `fgets' obj/topavalon.o(.text+0x64):../topavalon.c:39: undefined reference to `fclose' collect2: ld returned 1 exit status make: *** [epuisant.elf] Error 1 Build completed in 14.0 seconds The only things I've changed in the code ist that I want to read data from a txt file, coz the original code was a C one. I've inserted a the hello_hostfs.txt in the project folder and have the mount name mnt/host. So what could be the problem? Thanks
