21 years ago
About external SRAM
I have problems with my NIOS and external SRAM. any of your help are appreciated.
the case is as following:
I have a board built of my own, the board contain a Stratix chip EP1S20F780, and 4 SRAM chips , the SRAM are Cypress's CY7C1021CV33, which is a 64K X 16 bits SRAM, other than the IDT 71V416 SRAM. in my board 2 chips are linked each other to form a 32bits wide SRAM. so, from the FPGA's view, there 2 SRAMs in my board. each of them are 32 bits of width. only SRAM's OE_n, WE_n, ADDRESS and DATA signals are connected to EP1S20F780. all other SRAM's pins are connected to either VCC or GND.
my problem is: how to connect these 2 SRAMs to my NIOS2?
I have tried as the following steps, but tured to be a failure.
1) I wrote a Verilog HDL file about signals that need to be used between the avalon tri_state slave and the SRAM.
2) in the SOPC builder, I chose create new component.
3) in the new window, I add the new Verilog HDL file
4) chose interfaces as avalon tri_state slave type
But, there occurs the problem now, I can not change the data ports to inout. so, there shows the error message:
avalon_tristate_slave_0: slave has write signals but no data signal
avalon_tristate_slave_0: slave has read signals but no data signal
avalon_tristate_slave_0: slave must have a read or write interface or support interrupts
I have no idea of how to cope with this problem. can anyone give me a tutorial of how to add an external SRAM (other than the one on the development kits, i.e. IDT 71V416) to my NIOSII?
Thank you in advace.
regards
gong xuechun
    hi:qxc!
    have you done that question?i am now meeting the same with you,i have tried the ways as them said,but i still failed!can you give me some ideas,thanks in advance!
    I agree with Fischer!
    You should check off-chip memory if you can access it correctly!
    Maybe your sram's speed can't meet your system clock, that says
    Your sram is slower than nios2 cpu clock!
    --- Quote Start ---
    originally posted by yesdingsheng@Apr 17 2005, 08:47 AM
    hi:qxc!
    --- Quote End ---
    I have done the experiment using development board that the same as qxc have been described. I added the ram as user logic.My user logic interface file :
    module sraminterface(ram_data,ram_addr,ram_we,ram_oe);
    inout [31:0]ram_data;
    input [15:0]ram_addr;
    input ram_we,ram_oe;
    endmodule
    and my project's top entity file:
    module sram(clk,rst,ram_addr,ram_oe,ram_we,ram_data);
    input clk,rst;
    output ram_we,ram_oe;
    output [15:0]ram_addr;
    sramsopc mysram(clk,rst,ram_addr,ram_oe,ram_we,ram_data);
    endmodule
    my c file is:
    # include <stdio.h>
    int main()
    printf("hello from nios ii!\n");
    return 0;
    During the experiment ,I encountered two problem:
    1, In my user logic interface file , I set sram address width as 16bits,but in sopc bulilder generated file,it became to 18bits .
    2,there is no warning or error but the string displayed on the nios2 console is not "Hello from Nios II!".just some strange code.
    I wonder what&#39;s happened.
