21 years agoAbout external SRAM
I have problems with my NIOS and external SRAM. any of your help are appreciated. the case is as following: I have a board built of my own, the board contain a Stratix chip EP1S20F780, and 4 SRAM chips , the SRAM are Cypress's CY7C1021CV33, which is a 64K X 16 bits SRAM, other than the IDT 71V416 SRAM. in my board 2 chips are linked each other to form a 32bits wide SRAM. so, from the FPGA's view, there 2 SRAMs in my board. each of them are 32 bits of width. only SRAM's OE_n, WE_n, ADDRESS and DATA signals are connected to EP1S20F780. all other SRAM's pins are connected to either VCC or GND. my problem is: how to connect these 2 SRAMs to my NIOS2? I have tried as the following steps, but tured to be a failure. 1) I wrote a Verilog HDL file about signals that need to be used between the avalon tri_state slave and the SRAM. 2) in the SOPC builder, I chose create new component. 3) in the new window, I add the new Verilog HDL file 4) chose interfaces as avalon tri_state slave type But, there occurs the problem now, I can not change the data ports to inout. so, there shows the error message: avalon_tristate_slave_0: slave has write signals but no data signal avalon_tristate_slave_0: slave has read signals but no data signal avalon_tristate_slave_0: slave must have a read or write interface or support interrupts I have no idea of how to cope with this problem. can anyone give me a tutorial of how to add an external SRAM (other than the one on the development kits, i.e. IDT 71V416) to my NIOSII? Thank you in advace. regards gong xuechun
