21 years agoAbout external SRAM
Hi, I have problems with my NIOS and external SRAM. any of your help are appreciated. the case is as following: I have a board built of my own, the board contain a Stratix chip EP1S20F7...
21 years agoDear Fischer:
Thank you for your timely reply. First, I should clarify alougth the SRAM chips CY7C1021CV33-10 used in my circuit board has CE_n, OE_n, WE_n, ADDRESS, DATA, BHE_n and BLE_n control signals. but in our circuit board, only OE_n, WE_n(combined R/W). ADDRESS, and DATA are connected to our FPGA(EP1S20F780C7) whereas CE_n, BHE_n and BLE_n (Byte lane enable) are fixed connected to GND. I added the chipselect_n signal in my design as you told me in last post. but I still failed. Here is what I did and what problems I met. First, I open SOPCB, then open Component Editor. in the Component Editor, I created a Component, its name is CY7C1021CV33. under the Component Editor's signals button, I enter the following lines: ram_write avalon_tristate_slave_0 write_n 1 input ram_address avalon_tristate_slave_0 address 16 input ram_data avalon_tristate_slave_0 data 32 inout ram_read avalon_tristate_slave_0 read_n 1 input ram_cs avalon_tristate_slave_0 chipselect_n 1 input Under the interfaces button, I entered the following boxes: Name: avalon_tristate_slave_0 Type: avalon_tristate_slave Slave addressing: memory can receive stderr/stdout: yes/no (both cases was examined) setup: 0 readwait: 0/1 (both cases was examined) writewait : 0/1 (both cases was examined) hold: 0 After all these, I push the "Finished" button. a component named CY7C1021CV33 is generated, this will close the component editor and the component CV7C1021CV33 is automatically appeared in the User Logic group. In the SOPCB, I new a nios2 system. its name is "sram_test". in this nios2 system, first, I added a niosII processor, its clock is 50MHz, then I added a JTAG UART, a CY7C1021CV33 just generated, an avalon tri-state bridge. and linked the CY7C1021CV33 to the master. auto assign base address, then generated the NiosII system. After the NiosII system was generated, I went back to the QuartusII software. I newed a project here. in the project's top level, I wrote the following in verilog HDL: module external_sram(clk, reset_n, ram_address, ram_we, ram_oe, ram_data); input clk, reset_n; output [15:0] ram_address; inout [31:0] ram_data; output ram_oe, ram_rw; reg [17:0] bridge_address; reg sram_test my_sram_test(clk, reset_n, ram_cs,
