About DMA problem..please help me
hi all
I have try the altera memory test project with Nios II IDE.. but always display "-Testing memory using DMA"... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif the dma might be already open.. and didn`t display "Memory at 0x%X Okay"....... so...I found the code at nios forum...it should be work but it always display"wait for transfer to complete"...why? look like the same problem with memory test !? I use Quartus II 5.1 SP2 & Nios II IDE 5.1 SP1 the exception address is sram_0 at SOPC Builder the program memory & .rodata & .rwdata & heap memory & stack memory are sdram_0 and I sure I have connect the DMA read & write master with sdram_0 & avalon tristate bridge in the SOPC builder this is the code...please help me thanks.... # include <stdio.h># include "system.h"# include "sys/alt_dma.h"# include "alt_types.h" /* Create the transmit channel */ static volatile int rx_done = 0; /* ready handler*/ static void done (void* handle, void* data) { rx_done++; } int main (int argc, char* argv[], char* envp[]) { int rc; alt_u8 Inbuf[1024], Outbuf[1024]; alt_dma_txchan txchan; alt_dma_rxchan rxchan; void* tx_data = (void*) &Inbuf[0]; /* pointer to data to send */ void* rx_buffer = (void*) &Outbuf[0]; /* pointer to rx buffer */ if ((txchan = alt_dma_txchan_open("/dev/avalon_dma")) == NULL) { printf ("Failed to open transmit channel\n"); exit (1); } /* Create the receive channel */ if ((rxchan = alt_dma_rxchan_open("/dev/avalon_dma")) == NULL) { printf ("Failed to open receive channel\n"); exit (1); } /* Post the transmit request */ if ((rc = alt_dma_txchan_send (txchan,tx_data,1024,NULL,NULL)) < 0) { printf ("Failed to post transmit request, reason = %i\n", rc); exit (1); } /* Post the receive request */ if ((rc = alt_dma_rxchan_prepare (rxchan,rx_buffer,1024,done,NULL)) < 0) { printf ("Failed to post read request, reason = %i\n", rc); exit (1); } /* wait for transfer to complete */ printf ("wait for transfer to complete\n"); while (!rx_done); printf("Transfer successful!\n"); return 0; }30 Replies
thank you so much for the code.
Hello aprado, do you know how to configure DMA using VHDL in Quartus before we can run the code in NiosII? thanks!
Hello, using the Quartus you can instantiate it inside SOPC builder and set all the parameters you need
thanks. may i know how? if possible, can you pls provide a simple example? thanks!
Look at the first post of this thread, it is very detailed.
click on the icon in the left side of the ? at quartus to open sopc builder - Altera_Forum
i had done the sopc part. but i am stuck with the vhdl code in Quartus II. i thought we have to write the VHDL in Quartus II in order to be compatible with the sopc. only then, we can run the C code in nios2 ide. am i right? pls advise if i am wrong.
--- Quote Start --- i had done the sopc part. but i am stuck with the vhdl code in Quartus II. i thought we have to write the VHDL in Quartus II in order to be compatible with the sopc. only then, we can run the C code in nios2 ide. am i right? pls advise if i am wrong. --- Quote End --- SOPC Builder will generate the VHDL for the entire system which you then compile using Quartus II (as apposed to writing the logic manually). Once you have a programming file created by Quartus II you download the file to the FPGA and then you can communicate with the Nios II processor inside your SOPC Builder system. - Altera_Forum
Hi BadOmen, thanks for the reply! really? this is nice! i always thought i have to write the code manually. May I know how to generate the VHDL for the entire system? Thanks!
I recommend reading this tutorial, it'll explain all the steps:
http://www.altera.com/literature/tt/tt_nios2_hardware_tutorial.pdf http://www.altera.com/literature/tt/niosii_hw_dev_tutorial.zip - Altera_Forum
why my system stuck at:
--- Quote Start --- while (!txrx_done); printf ("Transfer successful!\n"); --- Quote End ---
