20 years agoAbout DMA problem..please help me
hi all I have try the altera memory test project with Nios II IDE.. but always display "-Testing memory using DMA"... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif the...
16 years agoYou could have a cache problem. The CPU could be reading its data cache instead of the buffer in memory.
Try to create a second pointer:alt_u8 *uncached_buffer = alt_remap_uncached(buffer,DEPTH);and when you print the contents of the buffer, read the data with uncached_buffer[x], and see if you have different results.
