16 years agoA question about Resolution of Framebuffer under uClinux
Hi all, I'm a newbie to uClinux and Nios II. Now I am able to use the UDP protocol to transfer an image from PC to DE2 board and show it in the VGA screen through the Framebuffer in a resolution o...
16 years agoThe vga controller supports higher resolution. You may edit the instance to change it.
You will need to modify the defs in nios2-linux/linux-2.6/drivers/video/altfb.c # define VGABASE na_vga_controller_0 /* Altera VGA controller */# define XRES 640 ==> 800# define YRES 480 ==> 600# define BPX 16 One thing to watch out is the memory bandwidth, which is tight on DE2. The higher resolution, the higher memory bandwidth consumed for display. - Hippo
