15 years agoA problem with nios-linux-20100621
Hi,everyone
My name is Baron,I'm portabling the uclinux.But when I download the image,the system can't start.I don't understand why,the .sof and image were download normally.You can see the picture.Thank you!1 Reply
probably more details could help people in giving you some hints. For example, if you are using a custom design or if you are using a modified example, a memory map could be helpful. I suppose you are using the NO-MMU version. I suggest to doublecheck an obvious thing: in kernel configuration the Altera JTAG UART is selected; the console option for this one is selected; no other serial device has the console enabled (to avoid watching a device while the output is on another). Regards Gabriele
