21 years agoA Newbie's struggle
I am sure the answer is simple but, I am running out of time... I am running Quartus II V4.2 with Nios II V1.1. My proprietary target system is based on the Cyclone EP1C2Q240C7, an EPCS ch...
21 years agoScott
Thanks for the path to the boot loader! The SDRAM tests were performed using the bit 31 cache bypass - in any event, the address test writes the full 16MB with unique values before reading it back for verification. From your experience, I suspect a hardware problem with SDRAM burst access not covered by my tests. From other postings here, I gather that the Nios II does not achieve back-to-back reads on its data bus, but does on its instruction bus. My tests would not detect this. I believe that the DMA is latency aware. Perhaps it would be a sufficiently challenging test to catch problems. I'll try.
