20 years agoA list of SOPC problems
1) custom component loses interface settings when changing the hdl files. This is particularly annoying for components with master interfaces, since the default choice is slave interface after the...
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- 1) can be solved very easy if you call the signals as altera recomments them[/b] --- Quote End --- Thanks for the naming. I can't believe I worked without knowing this, and it's right there in the docs http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif I also needed 'ats' for addressing external memory chip. Gladly this is a 16 bits (actually 18) device. I'm using the tri-state-bridge component with it as well. Can that solve your 8 bit memory mode problem? <div class='quotetop'>QUOTE </div> --- Quote Start --- 5) ... i add this file to a quartus project and do the analyze there until is does not mention any error or warning then i go back to the sopc[/b] --- Quote End --- I have Xilinx tools installed as well and easy to verify HDL in there. 6) Too bad that a SOPC system doesn't generate a SOPC component. Difficult to do that manually too because of the lack of proper prefixes. <div class='quotetop'>QUOTE </div> --- Quote Start --- 7) how should such a fifo behave ?[/b] --- Quote End --- Such a FIFO should be configurable much like the MegaWizard for lpm_fifo_*. Width, depth, synchronization/clocks, and status output to a slave control port. Interrupt to signal an under-/overflow and it could do avalon handshake to pause input when it's full. <div class='quotetop'>QUOTE </div> --- Quote Start --- 9) there is no external memory model to implement a external tristate bus to connect external devices[/b] --- Quote End --- tri-state-bridge can be used for external memories I think. 11) and how to get the base addresses for slave interfaces in some other HDL file instead of system.h? I could parse the pts file and output some HDL code for it... 12) Component Editor HDL analysis hangs on global (gls_*) signals ending with "clk"
