11 years ago4-NIOS design, only processor 0 fails to boot from flash at power-on
I have a design with 4-NIOS processors. A single flash part is used for storing the FPGA image as well as NIOS FW image. At power on, 3 of the NIOS processors successfully load from flash and beg...
10 years agoAre you referring to delaying the waitrequest signal? Where did you modify and how long was the delay added? Interested to find out your solution on this.
