11 years ago4-NIOS design, only processor 0 fails to boot from flash at power-on
I have a design with 4-NIOS processors. A single flash part is used for storing the FPGA image as well as NIOS FW image. At power on, 3 of the NIOS processors successfully load from flash and beg...
11 years agoCurious, do you know how long is your power-on reset versus reset button asserted?
Are you using EPCS flash controller provided in Qsys (EPCS/EPCQx1 Serial Flash Controller)? What version of Quartus are you using?
