--- Quote Start ---
I re-wrote the program again with the signal in there and REG replaced by Q but i am getting an error (Line 43: Syntax error near "signal".)
--- Quote End ---
That's because your declaration for Q was not in the right spot...see below
--- Quote Start ---
entity USR is
Port ( D : in STD_LOGIC_VECTOR (3 downto 0);
CLK, RST : in STD_LOGIC;
SIR, SIL : in STD_LOGIC;
S :in STD_LOGIC_VECTOR (1 downto 0);
Q : out STD_LOGIC_VECTOR (3 downto 0));
end entity USR;
architecture Behavioral of USR is
begin
signal Q :std_logic_vector(3 downto 0);
--- Quote End ---
Any signal declarations belong before the 'begin', like this.
signal xyz: ...
begin
end Behavioral
The next problem though is you've defined an internal signal called 'Q' which is also defined as an output of the entity. You can only define 'Q' once, otherwise you 'cover up' the outer definition. In this case, when you assign to 'Q' you will be assigning to the signal that is internal to the architecture, but there will be no way to assign to the 'Q' that is the output of the entity.
--- Quote Start ---
process(CLK, RST) is
begin
if (RST = '0') then
Q := (others => '0');
elsif rising_edge(clk) then
case S is
when "11" =>
Q := D;
when "01" =>
Q := SIR & REG(3 downto 1);
when "10" =>
Q := REG(2 downto 0) & SIL;
when others =>
null;
end case;
end if;
end process;
end architecture;
--- Quote End ---
As previously mentioned, you defined 'Q' as a signal which means you use '<=' rather than ':='.
I don't see where REG is defined at all...signal? variable?
Also, if you go back to my earlier post, you'll see that you didn't quite follow what (I think) I had which is that the assignment to Q is outside of the process. Something like this (just showing the bare bones, not all that you have)
process(...)
begin
if rising_edge(Clk) then
-- Set the signal 'REG' in here.
end if;
end process;
Q <= Reg;
What this structure will do is synchronously compute 'REG' (i.e. the inputs will get sampled, and a new value for REG will get computed only at the rising edge of the clock. The 'Q<=REG' assignment is immediate, whenever REG changes, Q will immediately change.
As for variables versus signals, there is nothing inherently wrong with using either one, the tools don't care, don't think that there is anything 'less good' about using variables. However, signals and variables don't do the same thing so how you use them is different. Here is are some code example snippets that are not meant to demonstate any function, just to point out some of the differences in how you use a signal versus a variable.
architecture EXAMPLE_1 of foo is
signal A: std_logic;
begin
process
variable B: std_logic;
begin
if rising_edge(Clock) then
B := xyz;
A <= B;
end if;
end RTL;
architecture EXAMPLE_2 of foo is
begin
process
begin
B := xyz;
end if;
end RTL;
A <= B; -- This is illegal because 'B' is not visible outside of the process
architecture EXAMPLE_3 of foo is
begin
process
begin
A <= B;
B := xyz;
end if;
end RTL;
Some points for you to review and consider.
- Variable assignments are immediate, if you single step through the code you can see immediately when the variable gets assigned, but not so with a signal. Some folks like that, others it doesn't matter.
- If you compare Example 1 and 3 you'll see that the only difference is the placement of the statement 'B := xyz' in the process. As written, the two will produce different results. However, if you change 'B' from a variable to a signal (and change the assignment from := to <=) then Example 1 and 3 will produce exactly the same thing.
- Variable are not visible outside the scope of the process. If you compare Examples 2 and 3, the only difference is the placement of the assignment of the signal 'A'. In example 3, the assignment is within the process but what it means is that there will be two clock cycles of delay between when 'xyz' changes and when 'A' changes. If you wanted to get rid of that delay you might think to move the assignment outside the process as shown in# 2, but this would create a syntax error because there is no 'B' that is in scope. The other solution is to move the assignment of 'B' to be before the assignment to 'A' as in# 1. In this simple case, that's probably the best route, but in a more complicated example it might not. The reason is that when you use variables, the order of the statements matters (like in a software programming language); if you change the order you change the behavior. With signals that is not the case, you can arrange the code as you see fit to better be able to maintain the code in the future. Since you are just starting out, this is not probably even on your radar, it will be if you start designing for real products down the road. If 'B' was a signal in Example 2, then the assignment of 'A'
could be moved outside of the process to get rid of the extra clock cycle delay.
- In the simulator,
signal waveforms can be added after the fact without having to restart the sim; variables cannot. To display a variable, you'll have to restart the sim, add the variable to the wave window for display and then run. Debugging goes much faster when you don't have to restart just to see what is going on. Signals allow that, variable don't.
In the end, both variables and signals have their places for use and how you end up thinking is the 'proper' way to use them is not necessarily the same as what someone else would think...neither person is 'right' or 'wrong'. Leaning more towards variables everywhere or signals everywhere simply reflects a person's preferences based on their historical use, how they first learned the language and many other factors.
--- Quote Start ---
like i said earlier that i am quite new to VHDL and i am still reading through all my notes and trying to get my head around it.
--- Quote End ---
Good luck...at some point everybody can clear the hurdle and things will seem much clearer. VHDL is not necessarily any easier or harder than any other language to learn...whether it is or not for a particular person depends on what they are used to with other languages that they have mastered.
Kevin Jennings
