16 years ago3c120, uClinux, nios2 ISP 1761
i'm trying to implement the ISP 1761 Host controller. For now, i'm using the 1760 driver of the 2.6.30 kernel, and use a usb memory stick as plugged device. if i put prink messages in the usb.c file, i can see that the init function is called, but nothing else is shown during the boot sequence and i can't see anything in the /proc/bus/usb/ Any clues or idea of i can test / try ? Does anyone already use a ISP 1761 on uClinux, with the 2.6.30 kernel ? (i ofen 2.6.17 references) PS: i'm pretty sure the the hard part is ok, because, thank to the nios2io i manage to access the isp register. Thx in advance, FPNo RepliesBe the first to reply
