10 years ago
16x2 lcd interface from 8 bits to 4 bits in the hal driver
Hi everyone,
I am trying to use the altera_avalon_lcd_16207 Driver to drive my Lcd and its working fine for me. But when I am trying to work with 4 bits interface using the same altera_avalon_lcd_16207 driver provided by the altera its not working. Find the below think I changed in the same driver.
________________________________________________________________________________________
line no : 548; file name : altera_avalon_lcd_16207.c ; function name : altera_avalon_lcd_16207_init();
original code :
/* Setup interface parameters: 8 bit bus, 2 rows, 5x7 font */
-lcd_write_command(sp, LCD_CMD_FUNCTION_SET | LCD_CMD_8BIT | LCD_CMD_TWO_LINE);
changed code :
+lcd_write_command(sp, LCD_CMD_FUNCTION_SET | LCD_CMD_TWO_LINE);
line no : 163 ; file name : altera_avalon_lcd_16207.c;function name : lcd_write_command();
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(base, command);
+command = command << 4;
+IOWR_ALTERA_AVALON_LCD_16207_COMMAND(base, command);
line no : 198 ; file name : altera_avalon_lcd_16207.c; function name : lcd_write_data();
IOWR_ALTERA_AVALON_LCD_16207_DATA(base, data);
+data = data << 4;
+IOWR_ALTERA_AVALON_LCD_16207_DATA(base, data);
the above are the changes i done so far in the given HAL driver. but not its not working for me.
So plz any one can suggest how i can solve this issue?:(
1 Reply
    Hi everyone,
    I got the solution for the above one and find the patch for the same.
    --- src/altera_avalon_lcd_16207.c 2015-04-23 11:17:46.000000000 +0530
    +++ src/altera_avalon_lcd_16207.c 2016-09-06 15:30:57.331296200 +0530
    @@ -161,9 +161,11 @@
    /* Despite what it says in the datasheet, the LCD isn't ready to accept
    * a write immediately after it returns BUSY=0. Wait for 100us more.
    - usleep(100);
    + usleep(1000);
    - IOWR_ALTERA_AVALON_LCD_16207_COMMAND(base, command);
    + IOWR_ALTERA_AVALON_LCD_16207_COMMAND(base, ( command & 0xf0 ));
    + command = command << 4;
    @@ -197,7 +199,9 @@
    usleep(100);
    - IOWR_ALTERA_AVALON_LCD_16207_DATA(base, data);
    + IOWR_ALTERA_AVALON_LCD_16207_DATA(base, ( data & 0xf0 ));
    + data = data << 4;
    sp->address++;
    @@ -577,8 +581,11 @@
    usleep(1000);
    IOWR_ALTERA_AVALON_LCD_16207_COMMAND(base, LCD_CMD_FUNCTION_SET | LCD_CMD_8BIT);
    - /* Setup interface parameters: 8 bit bus, 2 rows, 5x7 font */
    - lcd_write_command(sp, LCD_CMD_FUNCTION_SET | LCD_CMD_8BIT | LCD_CMD_TWO_LINE);
    + /* Setup interface parameters: 4 bit bus */
    + lcd_write_command(sp, LCD_CMD_FUNCTION_SET );
    + /* Setup interface parameters: 4 bit bus, 2 rows, 5x7 font */
    + lcd_write_command(sp, LCD_CMD_FUNCTION_SET | LCD_CMD_TWO_LINE);
    /* Turn display off */
    lcd_write_command(sp, LCD_CMD_ONOFF);
