21 years ago16 bit sram timing question
QUARTUS 5.0 NIOS 5.0 I have problems with the timing of an sram chip on a custom board. I don't know if it is some problem with reflections or something else. i use ISSI IS61LV25616AL 256k x 16 NIOS [A18..A1] -> SRAM [A17..A0] userlogic is setup as following: Bus Interface Type: Avalon Memory Slave PORT NAME | Width | Direction | Shared | Type address | 18 | input | yes | address write_n | 1 | input | yes | write_n read_n | 1 | input | yes | read_n writedata | 16 | inout | yes | data chipselect_n | 1 | input | --- | chipselect_n be_n | 2 | input | yes | byteenable_n when I select timing in interface to userlogic and change "Wait" e.g. Wait=2 it shown writen = 2cycles low, i think it should show 3 cycles low( one normal write cycle and two wait) when i select: setup=0 cycles wait=0 cycles hold=0 cycles and check the timing with the scope for the following byte ,word and dword accesses, then - there are unnecessary read cycles in case of 8 and 16 bit read - the dword 32 bit access has only one write strope and changes address within strobe ? the following show the timin g on the scope: setup:0 wait:0 hold:0 (one X is 10ns) BYTE(8bit) WRITE/READ (stb/ldbu) CS XX__XXXX__XXXX__XXXX WR XX__XXXXXXXXXXXXXXXX RD XXXXXXXX__XXXX__XXXX BE1 __XX____XX____XX____ BE0 ______________XX____ why second read access ? WORD(16bit) WRITE/READ (sth/ldhu) CS XX__XXXX__XXXX__XXXX WR XX__XXXXXXXXXXXXXXXX RD XXXXXXXX__XXXX__XXXX BE1 ______________XX____ BE0 ______________XX____ why second read access ? DWORD(32bit) WRITE/READ (stw/ldw) CS XX____XX__XXXX__XXXX WR XX____XXXXXXXXXXXXXX RD XXXXXXXX__XXXX__XXXX A0 ____XX________XX____ BE1 ____________________ BE0 ____________________ CS and WR are both low for 40ns ? only one write access for two 16 bit words ? is this timing normal ??? which documentation is actual up to date for avalon bus timing ?1 Reply
additional question
C:\altera\kits\nios2\components altera_nios_dev_kit_stratix_edition_sram2\class.ptf contains Hold_Time = "half_clock"; what does this means, how can I enter half a clock cycle in the "Interface to User Logic" editor ? thanks
