13 years ago16-bit shift left 2 register in VHDL
Ok, so I have a shift register (code below). But I need a shift left 2 register. So would I simply put "reg <= reg (14 downto 0) & '0' & '0';" ? Or do I need to do the shift process twice? I need help ASAP...any help would be great.
entity shiftreg is Port ( en : in STD_LOGIC; clock : in STD_LOGIC; reset :in std_logic; data_i : in STD_LOGIC_VECTOR (15 downto 0); shift : in STD_LOGIC; data_o : out STD_LOGIC ); end shiftreg; architecture Behavioral of shiftreg is signal reg: std_logic_vector (15 downto 0); begin process (clock, en,reg,reset) begin if reset<='1' then reg<=data_i; elsif (clock'event and clock <='1' ) then if (en <='1') then reg <= data_i; elsif (en<='1' and shift<='1') then reg <= reg (14 downto 0) & '0'; end if; end if; end process; data_o <= reg (15); end Behavioral;
