16 years ago16 bit avalon tristate slave
Hello I have a custom h/w for NiosII development using Cyclone III FPGA. I have 512k x 16 bit cypress SRAM. In SOPC builder I created a custom 16 bit Avalon tristate slave for SRAM interface. For ...
16 years agoThere could be a couple of reasons here.
And of course it is possible to mix different bit widths, the avalon switch fabric takes care about it when a master accesses a slave with a different bit width 1. do you get any timing waring during quartus compilation ? 2. have you checked your external signals against over and undershot ? undershots can lead to shifting the signal levels in a way that a component "thinks" it is active. 3. how do you do you timing control, via wait states or did set up the timing for setup access and hold ? 4. is you external memory attached as a memory or a register, i am asking about the alignment.
