RJain32's avatar
RJain32
7 years ago
" Downloading ELF process failed" Cyclone V GT Development board.(5CGTFD9EF35C7)
I am trying to access DDR3 memory using Quartus 18.1 subscription edition on Cyclone V GT Development board.(5CGTFD9EF35C7). I have used nios processor for programming purpose. I have interconnected all the required components (on chip memory, nios processor, DMA controller,
JTAG UART and external LED, DDR3, clock) using platform designer and set parameters of all components.I have used 100 MHz on board clock frequency oscillator to access DDR3 memory whose minimum data rate frequency is 300 MHz.After assigning pins to all input output port, I have compiled my design. My design compiled successfully and I have programmed my FPGA board by sof file.When I am trying to launch my nios processor to read/write on DDR3 memory, I stuck somewhere and got error " Downloading ELF process failed". I have rechecked my design, all the
pin assignment, reset and clock signal but still not able to identify exact issue of failure of launching of elf file on nios processor.
Kindly provide any solution
I have attached my qsys file (platform designer interconnect diagram).
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Hi Ruchi,
    Check your dip switch status of the reset pin.
    If reset is active you will face such an issue.
    Anand
  • RJain32's avatar
    RJain32
    Hello Anand, thanks for reply.
    I have checked the reset pin. It is configured properly. I got this message in run configuration " The expected Stdout device name does not match the selected target byte stream device name". I have checked my Stdout name, it is right. Kindly resolve the issue.
    AnandRaj_S_Intel
    Hi Ruchi,
    Can you check,
    1. Have you loaded the correct sof file?
    2. Eclipse project directory?
    3. Try by ignoring the timestamp mismatch of the system ID?
    Anand
  • RJain32's avatar
    RJain32
    Hi Anand,
    I got time-limited sof file which i have downloaded on my FPGA. I have checked the project directory in eclipse also and ignore the timestamp mismatch of the system ID, still i am getting the same error.
    Is there any problem with time-limited sof file?
    AnandRaj_S_Intel
    Is there any problem with a time-limited sof file?
    >>NO,
    Try to load the example project which comes with the installation kit.
    Anand
    • JPark222's avatar
      JPark222
      Is this issue resolved?
      I have a very similar issue with Cyclone10 GX (although I don't think it's device-related).
      Currently I’m having trouble downloading elf file (by command or nio2-eclipse GUI)
      nios2-download -g my_nios.elf
      The only error log I’ve got is this:
      Using cable "USB-BlasterII [USB-1]", device 1, instance 0x00
      Pausing target processor: not responding.
      Resetting and trying again: FAILED
      Leaving target processor paused
      Yesterday I successfully ran "hello world", but today no more.
      And digging on this, I found from Run Configuration page:
      The expected Stdout device name does not match the selected target byte stream device name.
      Is this just a warning or error I should fix? If error, how do I fix, please?
  • qwk000's avatar
    qwk000
    Did you resolve this? I'm seeing the same problem YEARS later. I have an old dev-kit, but need to get this working.
    Thanks!
