19 years ago__alt_stack_pointer misbehaving (linker bug?)
I am using Nios II 6.1 and 6.1 IDE. I use the following command (as recommended in another thread) to set the __alt_stack_pointer:
-wl,-defsym -wl,'__alt_stack_pointer=0x300000' I specify this command as a linker flag inside the IDE. The linker script has a comment for that symbol saying: " * the next two symbols define the location of the default stack. you can* override them to move the stack to a different memory." where the other symbol is __alt_stack_limit, which effectively points to the beginning of the heap (as far as I can tell from the linker script), and should always contain a lower value than the __alt_stack_pointer, because the stack grows from higher to lower addresses. System description: I have three processors in the system, all running code from an 8MB SDRAM: Processor 1: Reset Address = 0x00000000 Exception Address = 0x00000020 Processor 2: Reset Address = 0x00100000 Exception Address = 0x00100020 Processor 3: Reset Address = 0x00200000 Exception Address = 0x00200020 As can be seen, the first 2 processors have 1MB of memory each for their code and data. I would like to limit the memory occupied by the third processor to 1MB, so that I can use the remaining memory to store some data. Considering that, I thought it would make sense to put the initial stack pointer to 0x300000. However, when I do that, the linker reports:
"info: 5120 kbytes free for stack + heap." This didn't make any sense, so I tried to work out the relationship between the __alt_stack_pointer value I set, and the amount of stack space the linker reports. Here's what I got: __alt_stack_pointer, free for stack + heap. 0x300000, 5120KBytes 0x400000, 4096KBytes 0x500000, 3072KBytes 0x600000, 2048KBytes 0x700000, 1024KBytes 0x800000, 6090KBytes This doesn't make any sense to me. The stack space is reduced as I set the initial stack pointer higher and higher? Is this a bug (linker calculating the stack space incorrectly), or am I missing something? Thanks!
