如何约束altera_reserved_tck以及JTAG的相关信号管脚
- 4 years ago
I would suggest you set a 10MHz constraint to the altera_reserved_tck pin to constrain this JTAG clock.
The altera_reserved_tck pin is automatically generated for a design that uses a JTAG accessible module such as the SignalTap logic analyzer or the NIOS II debugger.
Thank you.
您好,
我建议的方案就是您试试把altera_reserved_tck管脚约束设置为10MHz。
这是因为SignalTap Analyzer或NIOS II debugger 引用了JTAG组件, 会自动化地引起altera_reserved_tck管脚.
谢谢
Kelly
Thank you.
您好,
谢谢
Kelly
