MEmel1
7 years agoWhy there's no clock on afi_clk output of the Hard DDR3 Memory Controller, although clock on pll_ref_clk input is present?
I've a problem running DDR3 HMC on Cyclone V SoC Development Board. I instantiated HMC megafunction in schematic top level file, made mem_ pin assignments, connected pll_ref_clk pin to CLK_BOT1 board...
BoonT_Intel
7 years agoHi, If you trace the RTL, you can see the afi_clk is direct connect from the PLL out_clk port.
So, the only reason why no clock is due to PLL is lose lock.
Can you monitor is the PLL_LOCK signal assert?
