14 years agowhy the on-chip dual clock ram has no read signal?
I add a on-chip dual clock ram with on-chip memory? but it has no read signal for two port,why? and how to read the ram with this circumstance? ??write high for write,and low for r...
14 years agoAre you generating this onchip memory for NIOS II as
in normal IP generation case i feel it rd_enable will be there but in Nios II situation we use IORD_32direct and read enable will not be available for user to control
