13 years agoWhy lpm_mult can not be synthesized?
Hello, everyone I recently have tried to use Lpm_Mult to accomplish a complex multiplication. But the Analysis & Synthesis part in the Compile Design can not be processed. There are two Errors...
13 years agoOk, in the design, Algorithm, I want to accompolish a complex number multiplication.
The real and imaginary parts of the complex number come from NumOneReg and NumTwoReg. When StartCacu gets high, the caculation starts. Then, four LpmMult entity accomplish four multiplication needed. After that comes two addition. In Quartus ii, when I tried the Analysis & Synthesis, the two syntax errors come out, which are (1) Text Design File syntax error: Text Design File contains '(' where ASSERT, CONSTANT, DEFINE ,DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected (2) Text Design File syntax error: Text Design File contains IF where ASSERT, CONSTANT, DEFINE ,DESIGN, FUNCTION, OPTIONS, PARAMETERS, SUBDESIGN, or TITLE was expected Please give me some advices. Thank you Below is the code. entity Algorithm is port( -- input Clk : in std_logic; Reset : in std_logic; NumOneReg : in std_logic_vector(31 downto 0); NumTwoReg : in std_logic_vector(31 downto 0); StartCacu : in std_logic; -- output CacuReg : out std_logic_vector(31 downto 0); CacuDone : out std_logic ); end entity; architecture Addition of Algorithm is type CacuState is (Idle, Load, Multi, AddAll,CacuEnd ); signal CacuFSM : CacuState; signal A_Real : std_logic_vector(7 downto 0); signal A_Imagine : std_logic_vector(7 downto 0); signal B_Real : std_logic_vector(7 downto 0); signal B_Imagine : std_logic_vector(7 downto 0); signal RealOne : std_logic_vector(15 downto 0); signal RealTwo : std_logic_vector(15 downto 0); signal ImagineOne : std_logic_vector(15 downto 0); signal ImagineTwo : std_logic_vector(15 downto 0); signal RealOneMid : std_logic_vector(15 downto 0); signal RealTwoMid : std_logic_vector(15 downto 0); signal ImagineOneMid : std_logic_vector(15 downto 0); signal ImagineTwoMid : std_logic_vector(15 downto 0); signal ResultReal : std_logic_vector(15 downto 0); signal ResultImagine : std_logic_vector(15 downto 0); signal EnMutiClk : std_logic; signal MultiCnt : integer; signal EnAddClk : std_logic; signal AddCnt : integer; constant MutiConstant : integer := 1; constant AddConstant : integer := 1; component LpmMult port ( clock : IN STD_LOGIC ; clken : IN STD_LOGIC ; dataa : IN STD_LOGIC_VECTOR (7 DOWNTO 0); datab : IN STD_LOGIC_VECTOR (7 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); end component; component LpmAddSub port ( add_sub : IN STD_LOGIC ; clock : IN STD_LOGIC ; clken : IN STD_LOGIC ; dataa : IN STD_LOGIC_VECTOR (15 DOWNTO 0); datab : IN STD_LOGIC_VECTOR (15 DOWNTO 0); result : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) ); end component; begin process(Reset, Clk) begin if Reset = '0'then CacuDone <= '0'; CacuReg <= (others => '0'); A_Real <= (others => '0'); A_Imagine <= (others => '0'); B_Real <= (others => '0'); RealOne <= (others => '0'); RealTwo <= (others => '0'); ImagineOne <= (others => '0'); ImagineTwo <= (others => '0'); CacuFSM <= Idle; EnMutiClk <= '0'; EnAddClk <= '0'; MultiCnt <= 0; AddCnt <= 0; elsif rising_edge(Clk)then CacuDone <= '0'; case CacuFSM is when Idle => if StartCacu = '1'then CacuFSM <= Load; end if;-- StartCacu EnMutiClk <= '0'; EnAddClk <= '0'; when Load => A_Real <= NumOneReg(15 downto 8); A_Imagine <= NumOneReg(7 downto 0); B_Real <= NumTwoReg(15 downto 8); B_Imagine <= NumTwoReg(7 downto 0); EnMutiClk <= '1'; MultiCnt <= 0; AddCnt <= 0; CacuFSM <= Multi; when Multi => if MultiCnt = MutiConstant then RealOne <= RealOneMid; RealTwo <= RealTwoMid; ImagineOne <= ImagineOneMid; ImagineTwo <= ImagineTwoMid; EnMutiClk <= '0'; EnAddClk <= '1'; MultiCnt <= 0; CacuFSM <= AddAll; else MultiCnt <= MultiCnt + 1; end if; when AddAll => if AddCnt = AddConstant then CacuReg(31 downto 16) <= ResultReal; CacuReg(15 downto 0) <= ResultImagine; AddCnt <= 0; EnAddClk <= '0'; CacuFSM <= CacuEnd; else AddCnt <= AddCnt + 1; end if; when CacuEnd => CacuDone <= '1'; CacuFSM <= Idle; when others => end case; end if; -- Reset end process; -- Multiplication A_Real_and_B_Real : LpmMult PORT MAP ( clock => Clk, clken => EnMutiClk, dataa => A_Real, datab => B_Real, result => RealOneMid ); A_Imagine_and_B_Imagine : LpmMult PORT MAP ( clock => Clk, clken => EnMutiClk, dataa => A_Imagine, datab => B_Imagine, result => RealTwoMid ); A_Real_and_B_Imagine : LpmMult PORT MAP ( clock => Clk, clken => EnMutiClk, dataa => A_Real, datab => B_Imagine, result => ImagineOneMid ); A_Imagine_and_B_Real : LpmMult PORT MAP ( clock => Clk, clken => EnMutiClk, dataa => A_Imagine, datab => B_Real, result => ImagineTwoMid ); -- Addition RealPart : LpmAddSub PORT MAP ( add_sub => '0', clock => Clk, clken => EnAddClk, dataa => RealOne, datab => RealTwo, result => ResultReal ); ImaginePart : LpmAddSub PORT MAP ( add_sub => '1', clock => Clk, clken => EnAddClk, dataa => ImagineOne, datab => ImagineTwo, result => ResultImagine ); end Addition;
