13 years agoWhy does MegaWizard create so many subwire connections even for the simplest ALTPLL?
Why does MegaWizard create so many interdependant subwire connections even for the simplest ALTPLL ( One clock input -> One clock output )? altpll_component : altpll PORT MAP ( ...
13 years agoIve seen subwires on all sorts of generated code.
I dont really care, as it usually maps properly, and I only care about the top level. You're not supposed to modify generated code (and generated code is always rubbish).
