13 years agoWhy does MegaWizard create so many subwire connections even for the simplest ALTPLL?
Why does MegaWizard create so many interdependant subwire connections even for the simplest ALTPLL ( One clock input -> One clock output )? altpll_component : altpll PORT MAP ( ...
13 years agoBecause it does. If you're really annoyed with it, I suggest you raise a mysupport request (but Ill doubt you'll get anywhere).
You could always instantiate the allpll yourself... if you dont mind messing around with the many parameters.
