ONors
6 years agoWhere is the HTML-report for altera_fir_compiler_ii documented?
When generating an altera_fir_compiler_ii a HTML file is produced. This HTML-file appears to be some kind of report or documentation. There is a name-value list called Parameters. For most of the nam...
ONors
6 years agoThe parameters in the IP Editor GUI is clear enough, no problems there. I do not suspect that I have any problems with the IP Editor.
Is there a way I can parameterize an IP from a list of parameters in a script without user interaction and without a GUI? If so, where can I find a guide on how to do so? This would be nice since it would remove some manual task and it will allow me to keep settings in a central place as opposed to values scattered and duplicated around in various GUIs that require manual editing.
